Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 11-23-2008, 10:01 AM
brockx's Avatar
brockx brockx is offline
1995 3.4 engine surges badly when cold
Hello from Jackson TN., first post.
I have a 1995 Cutlass Supreme Convertible with 26,000 actual miles. My problem is when cold starting the engine revs high when first started (kind of scary with a cold engine) then revs up and down (high to normal not slower) until it gets warmed up a little. Ideas please This is one of these deals where a mechanic will replace lots of stuff until he get's it $$$$$$$.
Old 11-23-2008, 12:35 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Re: 1995 3.4 engine surges badly when cold
Welcome to AF !
I'd first check for vacum leaks, especialy around the air intake.
Could be your Idle Air Control Valve- IAC is dirty/clogged passages. Might try cleaning it and the TB.
I would also check/test the wiring to the IAC and Mass Air Flow sensor- MAF.
I'll PM you a link for testing componets.
1999 Grand Am SS 3.4 OHV
Old 11-25-2008, 10:48 PM
tech JK tech JK is offline
The most common cause for this is the lower intake manifold gaskets are leaking vacuum. When they get old, they shrink and leak vacuum. When the engine warms up, idle will stabilize.
* GM Technician JK *
Old 11-25-2008, 11:06 PM
Scrapper Scrapper is offline
AF Premium User
i think mod just said the same thing about vaccum leak.
Old 12-20-2008, 03:07 PM
brockx's Avatar
Well it quit doing it. Don't make me mad at all, just puzzled. Thanks for the suggestions, really don't think it is gaskets, having the same weather etc.. seems like a gasket is either there or not assuming a reasonable ambient temp range.
The car hardly gets driven average is 2000 miles a year.
