Go Back   Automotive Forums Car Chat > AMC/Rambler/ Nash/IH > AMC
Old 11-23-2008, 07:49 AM
gearhead58 gearhead58 is offline
1988 Amc Eagle Wagon Problem!
When my Eagle Wagon sits outside overnight in the cold the front wheels lock. The car will not move and the back wheels will burn rubber trying to move it. In warm weather it is NOT a problem. Need information on what may be causing this to happens and suggestions for correction.
Old 11-25-2008, 11:59 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: 1988 Amc Eagle Wagon Problem!
That's a strange one. How cold are we talk'n here?
Old 12-07-2008, 08:55 AM
Unhappy Re: 1988 Amc Eagle Wagon Problem!
The tempeatures below about 35 degrees or so are what affects it. It is currently in for service with a fluid flush and change for the front differential. It also had the emergency brakes hanging up in the rear axel, so those are being replaced as well. Will have to see what this money pig does when it returns this time.
Old 02-06-2025, 12:35 PM
MariaJose's Avatar
MariaJose MariaJose is offline
It sounds like you may have a sticking brake caliper or a frozen wheel bearing. In cold weather, moisture can freeze and cause the brake components to seize. I'd suggest checking the brake calipers, rotors, and wheel bearings for any issues, and consider replacing or lubricating them to prevent freezing.
