Help - Desprate mom that can not get van into shop until 12/10/08 - Need to get to work Hoping that there is something that I can do to get in running by monday. Please HELP!
The van has worked well this week except needing one jump 6 days ago. Battery was replaced less than 8 mo ago, fuses are good, battery terminals are good, clean. I have heard many it could be things. I have to get this 1 ton paperweight going again and am simply at whits end. The car started having starting issues about 2 weeks ago, it would start and run rough. turn off and start again would be ok, next cold start nothing.. not starting but could be jumped.... Now No start no jump, it is turning over but not catching to continue to run. |
Re: 01 windstar won't start or Jump
IDMOM
Welcome to AFs! Sorry you're having trouble. How long have you owned the van? How many miles do you have on it? Has the CEL (check engine light) been on? Post back and we'll see how we can help out Regards Dan
******************************************* Wiswind's Windstar repair pics http://community.webshots.com/album/201931518cScpNK Photos of my repairs: http://dansautopictures.shutterfly.com/ Check this out:http://threewheelmotorcyclemetro.shutterfly.co A must read about problems Windstars have: http://www.automotiveforums.com/vbul...d.php?t=672854 95 Windstar 240,000+ 98 Windstar 136,000+ 09-25-2008. 85 Dodge 1 Ton Snow mover gas hog 91 Mazda Protege free beater SW MN |
somethings draining battery or alt is not charging so souds like you just been running on battery. i'd get it chaged up and take it to auto zone and see about alt i think alt not charging? or you may check starter that will drain it also.but first stop auto zone or advanced.
Are you saying the starter turns it just fine in the last paragraph, but it won't fire and run? What's the mileage and the last tuneup?
Definetly sounds like the alternator. My daughter in-laws,(99 Windstar), did the same thing. Alternator was bad.
Welcome to the forums, but first things first.
Does the van have a keyless entry or security system to it? If so next time it refuses to start you can try cycling thru between loking and unlocking the doors to possibly reset the system. Also, when it refuses to start at all have you :
I'd be definitely be checking the alternator. Go to a local autozone or similar parts place. They can check the alternator while it's in the van. This is assuming that you can get it running! I'd also look at the rear brake light cluster (the one in the back window). My wife's van had a bulb out in that 3 and it caused the battery to drain and had similar symptoms to yours. It may be that bulb draining the battery and a bad alternator not charging.
Piper
----------- 2000 windstar 3.8 2010 honda pilot touring Muskoka Canada |
However, I don't believe that it's the battery. It was running rough and something was causing this. What ever this is may have changed from causing rough running to a no start condition. Have you had any luck with any of our suggestions? Dan
LaSabre97mint - the van has been in my possession for almost two years(will be in feb) has 96000 miles on it which I have put on 10,000 of. The CEL has been on with frequent checking to make sure there are not more codes being dropped - it has only been dropping the code about an down stream o2 sensor. My Mechanic said that it would be fine with out replacing it.
The Jump factor -- the starter does not speed up nore is there any drag on the other vehicle when trying to jump the Van. Others - Has had new battery in the last eight months and is holding a good charge.. the last tune up was in the end of 07 and was actually getting set for another.. *grumble grumble* It has keyless entry and the system works fine. I have checked all the fluids the oil was low and has been topped off. the others were all fine. Tried Neutral instead of Park and still just turnover and no start. We were checking spark plugs and my husband turned it over and it started- turned it off to remove the tester and now again nothing....
I sometimes have trouble understanding "starting" or "not starting".
The engine is "cranking" (turning over), but then not "running" ... or not "cranking" at all?? (If it is "cranking", why are you sometimes jumping it off?) ..or, Does it "crank", then "run" a bit, and then stop? Has the battery voltage been read during any of these events? |
IDMOM
What kind of tester was used to check the spark plugs? I'm looking for a reason why it would run with it attached and not with it disconnected. Dan
The van was cranking and not catching or firing up.
The van was picked up by a tow truck last evening and is now at the shop to get fixed... Thank you for all of your assisstance. The troubleshooting that I had completed was that I had checked the terminals and battery cables and charge. I have checked all the fuses and they were all in good working order. The fuel pump was working fine. The spark plugs are delivering spark. --- I believe that I have eliminated all suspects xcept fuel. |
IDMOM
I for one would like to know what the shop finds out. Please post back when you know Dan
