Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 11-22-2008, 12:30 PM
Spongebob5961 Spongebob5961 is offline
Question Re: blower problem
Don't mean to hijack the thread so if anyone can redirect me to a previous post for help, fine. Having said that, I have been given a 1995 Caprice Classic, 5.7 with 49,000 orig.miles, one owner. Only real problem I've got is the heater/ac motor only works on high setting.
I ordered a new motor, pluged it in and still only operates on high. What's next?
All help appreciated.
Old 11-22-2008, 12:45 PM
RageCage RageCage is offline
Re: blower problem
Try rasping the contacts by rapidly turning the knob up to high, then back down to low several times. It worked for my 85 Caprice. I had the same problem. The idea is to wear off the corrosion that has built up on the switch contacts behind the knob. Sounds wild, but it worked. Don't know if you have the same type of knob on your 95.
Old 11-22-2008, 01:10 PM
j cAT j cAT is offline
Re: blower problem
your vehicle blower if its manual not autmatic hvac controlled ,,has a resistor module on the passenger side under the dash with the high speed only this points to the resistor assembly...when your in the max speed no resistors are used...the relay is commanded to pull in and 12v is applied to the blower...
you are a hijacker!!!
Old 12-04-2008, 12:51 PM
Re: blower problem
Ok, j cAT,
speaka-da-english to me about this module thingy....no seriously, I know a little but please explain. Thanx.
Old 12-05-2008, 06:48 AM
iroc343 iroc343 is offline
Re: Blower problem - 1995 Caprice
As j cAT said, there is a resistor module located on the passenger side above where someone's feet would rest. There are three screws holding it in place. It is a dealer only item, cost around $30. There are three coils on the board and the electrical connections usually rust away.
