1990 dodge
NEED SOME HELP--I HAVE A 4 WHEEL DRIVE DODGE--WHEN THE TRANS SHIFTS INTO 3RD I GET A GRINDING SOUND--AROUND 40MPH---IF I PUT IT IN O/D THE SOUND GOES AWAY--THE QUESTION IS --DOES THE TRANS HAVE TO BE PULLED TO FIX---ANYONE KNOW?
THANKS FOR THE TIME [email protected]
Re: 1990 dodge
Sounds like something in 3rd...what does the transmission fluid look like? Does temperature change anything? What do you think about maybe a loose motor mount is letting the fan rub against the fan shroud?
1992 Bravada, 201K, stock 1997 Bravada, 101K, stock...was "called away" ![]() "Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14 ![]() Time to turn so's you don't burn.
Re: 1990 dodge
Changed Fluid Yesterday--looked Pretty Burnt--------just Going To Drive It In Overdrive All The Time----thanks For Your Input.later
