Old 11-21-2008, 11:57 PM
86foxbody's Avatar
86foxbody 86foxbody is offline
Help Help Help
ok im a beginner and i want to do everything myself so i replaced the flywheel and starter. my battery was dead after i did this the clutch and everything seemed ok so i set the car down to push start it down my driveway i push the clutch in and set it in revese the car just stoped and now its stuck in revese and it wont come out did i put somthing back together worng or what idk
Old 11-25-2008, 03:45 AM
Davescort97 Davescort97 is offline
Escort guy
Re: Help Help Help
The clutch release bearing probably slipped off the yoke and is making it stuck in reverse. But, before you tear it down again, check that the clutch slave cylinder is moving by watching it and having someone else operate the clutch. If you can get it to a level area have someone rock the car back and forth while you try to get it out of reverse. If that won't work you will have to redo the job. Hope you get it out. You should only have to do a job once.
