Old 03-19-2003, 07:16 AM
Crxce Crxce is offline
Send a message via AIM to Crxce
Top 10 hp robbing things
What are the Top ten hp robbing problems or components on a engine just looking for every bit of power i can find
Old 03-19-2003, 07:33 AM
OneSloCRX OneSloCRX is offline
anything that draws power from your engine.. like air conditioning... power steering.. etc.
Old 03-19-2003, 07:40 AM
Melt's Avatar
Melt Melt is offline
Send a message via AIM to Melt
one slo pretty much covered it. Larger diameter rims also rob HP, people run 13's on the front for a reason.
AF Bay Area Crew
97 Toyota T100 xcab 3.4l v6 5spd 2wd
Old 03-19-2003, 07:49 AM
BLU CIVIC's Avatar
BLU CIVIC BLU CIVIC is offline
調整器
Send a message via MSN to BLU CIVIC Send a message via Yahoo to BLU CIVIC
PASSENGERS
The name's Adrian
1990 Civic HB Si - 265.7whp/223tq @9.2psi. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 296.3whp/230tq @1bar. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 185.8whp/139tq. Tuned on NepTune by J.Mills
2006 G35 Coupe 6MT - Stock
2011 CR-Z - Stock
Old 03-19-2003, 08:29 AM
IM4U2NV81 IM4U2NV81 is offline
Send a message via AIM to IM4U2NV81
think of your motor as an air pump. Anything that henders airflow will restrict HP. Think air intake, exhaust manifold, puny size exhaust. Slocivic stated the obvious when saying that a/c and power steering rob HP. They are parasitic meaning, they take from the motor to perform their operations. Things that may not "rob" HP buy may hinder it may be your ignition system. But, honda ignitions are pretty sufficient to begin with so start somewhere else first. An aftermarket cam is always a nice place to find another 5-15 HP. Just think "more air=more fuel to burn=more power"
Old 03-19-2003, 08:33 AM
Bleebdat Bleebdat is offline
Send a message via AIM to Bleebdat Send a message via Yahoo to Bleebdat
Faulty electricals, bad grounds, bad plugs, fuel delivery issues, and so on.
Old 03-19-2003, 09:50 AM
VelocityCivic91's Avatar
VelocityCivic91 VelocityCivic91 is offline
Send a message via AIM to VelocityCivic91
Dont forget the cat, and the resinators... they dont add power. Also, weight. That is the only handicap that our cars have comparied to most other Hondas. Losing weight, it helps.
WARNING: Surgeon General says it's O.K. to smoke V-8's.
*** Looking for a B&M fuel pressure regulator and guadge***
Old 03-19-2003, 11:02 AM
contrary to what you say, the cat and resonators are there for a reason. True, they don't add power. but, the do add VALUABLE backpressure (new word I guess) and do greatly affect drivability. If you are drag racing ONLY, sure, hack them. If you plan to drive this car daily, DO NOT, hack them. Backpressure is something the motor NEEDS to be drivable in the lower to mid RPM range. It's called "scavenging". If you do the exhaust, step up to 2.25" piping w/ cat and a resonator. It won't be loud and it will give you a good midrange (where most driving occurs for normal people).
Old 03-19-2003, 12:20 PM
I have heard plenty of arguement for and against back pressure, if you are running 2 in or 2.25 exhaust system, taking out the cat for a test pipe or switching to a high flow muffler will only take away a little power down low, but the mid and high range will greatly improve.
Old 03-19-2003, 12:33 PM
Stali08's Avatar
Stali08 Stali08 is offline
Send a message via AIM to Stali08 Send a message via Yahoo to Stali08
so is having a fat girl as your passenger, and a dead body in the trunk......I dont know where that came from, but I typed it so it doesnt mean shito
PeacE
Old 03-19-2003, 03:07 PM
plkelley's Avatar
plkelley plkelley is offline
Send a message via AIM to plkelley
The diameter of the wheel has nothing to do with it...its the wieght. You can get 16's that wiegh less than 13's...their pricey but out their.
Honda...An Army Of One
Old 03-19-2003, 07:29 PM
Dx18704 Dx18704 is offline
Send a message via AIM to Dx18704
well i beg to differ because the bigger the wheel the more power it needs to spin it and get momentum sp??
\m/ (-.-) \m/
Rock and Roll will never die
Old 03-19-2003, 07:32 PM
GTA's Avatar
GTA GTA is offline
Whee..
also known as the rotational mass of the wheel...
AF Bay Area Crew
RIP Melt
2008 Mitsubishi Lancer Evolution GSR
2007 Toyota Prius
I <3 and miss my 4g
Old 03-19-2003, 07:47 PM
FourthGenHatch's Avatar
FourthGenHatch FourthGenHatch is offline
Send a message via AIM to FourthGenHatch
The thing I don't understand is my Rota weighs 12lbs and the tire weighs 20 lbs. So even if you had a light rim or a small rim the tire is heavier and farther away from the center so why does a small rim really matter as the tire will be heavier.
http://www.fourthgenhatch.com
FOR SALE: Get this stuff out of my house!
-Stock hood (red) $30
-Stock Rear Spoiler (red) $30
-Stock mirrors $30/both
-Stock side front and rear side glass $30/piece
Old 03-19-2003, 07:48 PM
91civicDXdude's Avatar
set something straight here
when people say a bigger exhaust will take away torque or horsepower at low rpm, this is simply not true at all.
The Torque/horsepower simply moves upwards in teh powerband.
