Old 11-21-2008, 10:22 PM
combonumber5 combonumber5 is offline
1992 Dodge Stealth TT clutch help
Hey unfortunatly the clutch for my 1992 dodge stealth twin turbo (manual) is pretty worn (very low and hard to shift espicially out of the parked osition) and I need a new one. So basically im looking for sugestions for some good quality clutch kits.
Old 11-22-2008, 08:08 AM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: 1992 Dodge Stealth TT clutch help
It sounds like you have hydraulic issues and not clutch issues. If it was clutch it would slip. Having trouble shifting, especially out of nuetral means you have air in your lines.
Old 11-22-2008, 05:44 PM
95DodgeAvenger95's Avatar
95DodgeAvenger95 95DodgeAvenger95 is offline
Send a message via AIM to 95DodgeAvenger95
yea, air in the line, low clutch line fluid, or ur old line is weak and when u hit the pedal the line expands. all could cause rough shifting, ur clutch is more than likely fine, but if u do decide to in the future to mod ur car i would recomend an rps clutch from www.pricematchedparts.com good luck
Black 96 3000Gt Vr4 58k mi, H.H.H. Data logger, RPS MAX, Big16G/14b Combo, FMIC, AEM EUGO, Greddy EBC, SAFC II, 560's, hotwired 255lph, not cats, Solid motor mounts, Faze boost gauge, Apexi turbo timer, full exhaust with 3" ICH Single shot Catback, K&N Air Filter, Front upper strut brace, T-Case Bracket, AC delete, Meth injection, NGK stg 1 colder, 8k HID'S.
AIMING FOR 500+AWHP at ips dyno.
Old 11-23-2008, 11:58 PM
Thanks guys ill check it out and repost if something comes up
Old 11-26-2008, 12:28 PM
jason_bet's Avatar
jason_bet jason_bet is offline
Send a message via MSN to jason_bet
I agree with these guys. Check your fluid first and then check your rubber section of hose for a leak. This is a good part to replace if you have having issues. If you change your Slave I would change this at the same time
Jason
