Go Back   Automotive Forums Car Chat > Chevrolet > Malibu
Old 11-21-2008, 07:15 PM
tjr19136 tjr19136 is offline
gas meter gauge problem
I have a 97 malibu with the 3100 engine; I went to replace the headgasket and i just gave up and said i was going to just replace the engine. I put everything back and now the gas gauge is under the black needle..........
What and how can that happend........
Old 11-21-2008, 07:44 PM
cf1 cf1 is offline
Re: gas meter gauge problem
If the gas gauge worked befor you replaced the engine, check you fusses and the wires that you had to unhook..
Old 11-22-2008, 02:46 PM
bearcatdon bearcatdon is offline
Put a paper clip through the trip reset hole and raise the needle above the black stop. This is an issue with many Bu's when the battery gets disconnected. It helps to do it with the ignition on.
Old 11-22-2008, 04:31 PM
So I am suppose to push the reset black needle in and take a paper clip and put it through the reset hole. Then use the paper clip to push the gas gauge needle in and I guess the gas gauge would go back up...........
Old 11-27-2008, 02:12 PM
The clip should fit in between the button and the glass. You then have to lift the needle above the black stop. If the ignition is on, the needle should raise once you clear the black stop.
