Old 11-21-2008, 06:02 PM
CoolasIce CoolasIce is offline
Source for O ring replacement
I'm looking for a simple O ring about 1/4" on diameter to replace a leaking one at the end of a Ford power steering hose. It screws into the steering rack.
The hose is fine, and I want to save it, instead of replacing the $50 hose because a 20 cent O ring is leaking.
Can someone recommend someplace where I can purchase a simple O ring?
I assume it is neoprene. Will an O ring meant for plumbing work?
Will a dealer be able to match it?
Thanks.
Old 11-21-2008, 11:41 PM
H23A1Lude H23A1Lude is offline
Send a message via AIM to H23A1Lude Send a message via Yahoo to H23A1Lude
Re: Source for O ring replacement
Take that o-ring off, and go to Ace Hardware, Autozone, etc. Just match it up.
1994 Honda Prelude Si H23A1
Me: Get new U-Joints, then your Ford won't suck as bad.
Him: Do I need o-rings?
Me: No you idiot.
Him: Sorry, I've never replaced an O-Joint before
Me: FAIL
Old 11-22-2008, 10:10 AM
curtis73's Avatar
curtis73 curtis73 is offline
Professional Ninja Killer
Harbor Frieght sells a box of something like 300 assorted O-rings for $10. Not sure if the quality is up to the task of sealing high pressure power steering fluid, but worth a shot.
Dragging people kicking and screaming into the enlightenment.
Old 11-22-2008, 04:49 PM
OK, thanks.
Old 11-24-2008, 06:46 PM
Blt2Lst's Avatar
Blt2Lst Blt2Lst is offline
Just make sure the material the o-rings are made from are compatible with petroleum products. If they are EPDM, no good,
Should be at least viton or neoprene.
Good luck
Al
1989 Caprice Classic Wagon, Olds 307 ,SMI Q-Jet, 200R4 w/Shift kit, Flowmaster 50, Hotchkiss sway bars, KYB Shocks. Jet Chip,
1989 Mustang LX 5.0 5sp convertible
1992 Camry LE 2.2
1996 Suzuki RMX250
I'm a victim of circumstance [
