Old 11-21-2008, 03:52 PM
Rooy Rooy is offline
Hatch holding device for weak struts?
I swear I remember seeing some sort of bracket or rod or nifty device being sold that would hold the hatch up, but I'll be damned if I can find any such device. I thought I saw it in a JC Whitney catalog, but searches on their website aren't turning anything up and I don't have a catalog handy.
I'd buy new struts, but I'm pretty sure they were already replaced once around 2000 on my 91 Metro. It isn't worth it to me to pay $40 or so for new ones if that's all the longer they last. The piece of 1"x1" currently in use is not convenient.
Anyone come across this hatch-holder device before?
Old 11-21-2008, 04:35 PM
old_master's Avatar
Advisor/Moderator
Re: Hatch holding device for weak struts?
Keep a pair of vise grips in the car. Open the hatch and clamp the vise grips on the shaft. Cheap temporary fix.
Old 11-21-2008, 04:57 PM
bennie442 bennie442 is offline
Advance Auto (and others, I'm sure) have a spring loaded rod that clamps to the strut stem that will serve as a holding device. When you open the hatch, the rod will fall into position and rest against the strut body to hold the hatch open. When you close the hatch, lift the hatch slightly and disengage the rod.They are a universal design that you trim to fit.
Old 11-21-2008, 05:21 PM
Ah yes, that sounds like what I remember seeing. Thanks a bunch!
Old 11-21-2008, 06:51 PM
Fatslicks Fatslicks is offline
Does anyone have a link?
Old 11-21-2008, 11:30 PM
DOCTORBILL's Avatar
DOCTORBILL DOCTORBILL is offline
Geo Metro Lover
Tell you what - I have a real cheap fix....an old broom handle.
Lay it flat in the back cross-ways, open the Hatch Back, pick up the Broom Handle
and prop up the Hatch at the window corner....
Works every time.
Dog Dirt Cheap.
Will not "freeze up" nor rust nor die.
The Wind can't blow hard enough to flop the Hatch down.
DoctorBill (El Cheapo Ritzo)
Old 11-22-2008, 04:51 AM
doug2060 doug2060 is offline
I have a very nice blue broom handle. It's hollow (weight reduction)...
Old 12-10-2013, 04:59 PM
GeoRandy GeoRandy is offline
I use a white 1/2" PVC pipe cut to fit. It never falls.
I like the mini vice-grip idea though. I will dip the business end in Plastidip a couple of times so the teeth won't eat up the rods.
Old 12-10-2013, 05:17 PM
Crvett69's Avatar
Crvett69 Crvett69 is offline
you can also put a slight bend in the struts, or a piece of white pcv with a slot cut in it, when you lift the hatch up slide the pipe up the strut and set it on top of the strut cyl, when you want to lower hatch just slide it down the cyl and close hatch or you could pony up the $30 and get a brand new pair of struts for it
