Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 2nd Gen 00-05
Old 11-21-2008, 03:04 PM
82Stang 82Stang is offline
Intermittent no start...
2001 Dodge Neon 2.0L 8th digit vin C Auto
Car runs well, but on occasion it will not start. Turn the key and nothing, no dashlights or crank or anything. Doesn't seem to matter whether cold or hot. I could drive to the store, come out and it won't do anything. Then try again and it's fine. I also get no codes.
Could it be an ignition switch/Cam sensor/CPS?
And how to check for a specific cause.
Thank you.
"When I was a kid my parents moved a lot, but I always found them."
Rodney Dangerfield
Old 11-22-2008, 01:29 AM
discnik discnik is offline
Re: Intermittent no start...
I had the same thing on a Saturn. It was the starter starting to go. To test this take a test light attach clip to solenoid terminal on starter, ground the test probe, turn ignition switch to "start" position. You will of course need two people for this. If the test light lites up but the starter does not crank your solenoid is headed for "Boothill". Hope this helps.
Old 11-26-2008, 07:53 AM
I overlooked the starter. It's probably it. TY
Rodney Dangerfield
