Old 11-20-2008, 07:30 PM
jjr123 jjr123 is offline
problem
The speedometer, and all the other markers in the dashboard are not functioning. Even while the van is running its speed, gas, cooling, etc. markers dont work(markers stay at zero and do not move). The serve engine soon and CBS signal are also turned on.
Any help appreciated........
Old 11-20-2008, 08:42 PM
tempfixit tempfixit is offline
Re: problem
What year and engine??
Sounds like a instrument cluster sodier connection problem.
Read this post:
http://www.automotiveforums.com/vbul...nt+cluster+fix
Also go to the upper right hand corner above the listed threads and click on search forum and enter instrument cluster fix, many helpful threads and tuitorials
Hope this helps
Old 11-20-2008, 09:10 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: problem
Smack the dash above the instrument cluster. If something comes back to life it indicates a solder joint issue as tempfixit stated. Could still be the case even if nothing comes back.
Go to the fuse/relay panel (PDC) next to the battery and remove the IOD fuse for 2-3 minutes. This will reset the body control module which controls the cluster.
Push in the two knobs on the instrument cluster. This starts the cluster calibration sequence. All the indicators should cycle a few times then return to normal. If the pointers move the cluster is good.
Next time when you type your title to your post give us a clue as to the subject of the problem. "Problem" doesn't help anyone searching for information about the issue they are having with their car.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
