Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 11-20-2008, 09:53 AM
clevername88 clevername88 is offline
Heater only works on highest setting
I have a 1995 Jeep Grand Cherokee. For the last couple of weeks I had a problem where I would turn on the heat and drive for a while then once I got to my destination I shut off the jeep and the blower for the heater kept running. I had to disconnect it so the battery wouldn't die. Then last night the problem went away but now the heater only works on the highest setting. I had a similar problem with my Pontiac Grand Prix recently and found it to be just a bad resistor. Might this be the same problem?
Old 11-20-2008, 11:55 AM
Bob D. Bob D. is offline
Re: Heater only works on highest setting
Most likely. I've seen this problem before on older Grands, can't recall where the resistor located though.
Old 11-20-2008, 05:01 PM
dksob81 dksob81 is offline
Send a message via ICQ to dksob81 Send a message via AIM to dksob81 Send a message via MSN to dksob81 Send a message via Yahoo to dksob81
your resistor is bad. it is located under the passemgerside dash right next to the blower motor, should have 2 screws holding it in.
R.I.P. - 94 Jeep Grand Cherokee Limited 5.2L V8 Quadra-Trac, 3" Budget Boost, K&N FIPK Gen II (Cold Air Intake), FlowMaster American Thunder (Exhaust).
W.T.T.F. - 1998 Jeep Grand Cherokee 5.9 Limited - Deep Slate Pearl - K&N FIPK GEN II (COLD AIR INTAKE), Altezza Tails and Crystal Clear Front end light with HID Kit and NP242 Swap.
