Old 03-19-2003, 02:05 AM
SIvic SIvic is offline
d series buildup?
hey guys what do you think of this possible setup?
d16a6 or sohc ZC block
d16a1 pistons (pg7?)
d16y8 head
d16y6 intake manifold
b18b LS t/b - 60mm
as far as installing this into a 90 civic.....converting to OBD-1 is easily changeable to create a "ecu - harness" or do all the plugs not fit from the 88-91 over to the new grey plug 92-95?
thankyou for any input..
Old 03-19-2003, 04:59 AM
Kunundrum's Avatar
Kunundrum Kunundrum is offline
Send a message via ICQ to Kunundrum Send a message via MSN to Kunundrum
everything sounds like it should fit
2012 VW Golf 3 Door Automatic (Company Car)
2011 VW Golf Wagon 5 speed (Company Car)
2010 VW Jetta 2.5 Automatic (Company Car)
2009 VW City Jetta 5 Speed (Company Car)
2009 VW GLI 6 Speed (Company Car)
2008 VW Jetta 2.0T 6speed (Company Car)
1999.5 Audi A4 Quattro Sport 1.8t (Chipped 1.0 bar) Sold
1990 CRX Si (Built B17a) - Stripped and Crushed
1988 CRX Si -- Stolen
1990 Civic Cx -- Sold
1990 Civic Si -- Parted
1989 Civic dx -- Sold
Old 10-08-2003, 06:11 PM
civici civici is offline
Send a message via MSN to civici
D16Y6?!
Where can you find parts/mods for that f*cked up engine?!
I have a 1999 civic VTi and it has a D16Y6 engine. I've been searching the whole web for anything for my engine's type and still couldn't find anything.
"let's be honest guys, non of us will ever date a model!" - Bubba Sparks
Old 10-08-2003, 06:55 PM
91civicDXdude's Avatar
all d series intake manifolds are interchangeable.
all SOHC d series parts are interchangeable for that matter, except for a couple small things on certain engines, but for the most part, any d series part will fit any other d series engine
Old 10-08-2003, 07:02 PM
KoRnSaQ KoRnSaQ is offline
Send a message via Yahoo to KoRnSaQ
sounds like a good setup man, be sure to let us know how it turns out
KoRnSaQ
Old 10-08-2003, 07:04 PM
just a thought..
you better have full time acces to some 110 octane race fuel with that 13.4:1 compression you're goign to have
Old 10-08-2003, 09:59 PM
Jay eS Iye's Avatar
Jay eS Iye Jay eS Iye is offline
Send a message via AIM to Jay eS Iye
Re: d series buildup?
never heard of a y6, but if you mean z6, stick to the y8 manifold, its hella big
The Civic is gone...
The Camry never ran...
The Chevy is here to stay...
The Ultimate Honda Engine
Old 10-09-2003, 02:03 AM
RedRacerCivic's Avatar
RedRacerCivic RedRacerCivic is offline
Send a message via AIM to RedRacerCivic
d16a1 pistons = P29
-1991 Civic Si (Sold)
-1990 Accord EX(Sold)
-2000 Civic Hatch
-1998 Lexus SC300
Click here to see my Shoe!
Old 10-09-2003, 05:58 AM
There are lots of D16Y engines starting from Y1 to Y8.
Mine is D16Y6 >> 1.6L (SOHC) VTEC. 115hp, RPM redline 6.800 -stock-
I haven't found anything for this engine. One f*cked up engine!
Old 10-09-2003, 09:11 AM
i told you, any d series parts will work with your engine. just becuase it is called D16Y6 doesnt mean that D16Y8 parts wont work with it. It appears identical to a D16Y8 to me, only detuned.
Old 10-09-2003, 10:27 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
some one told me that a hf block with a 5thgen head or i guess 6th gen would work too, will yield mad comp ratio and is good for like low 15s. idk if true but soemone told me that
Team Lonely Drivers
Old 10-09-2003, 11:14 PM
hilltopper hilltopper is offline
if you need more info on d series engines go herehttp://www.d-series.org/
Old 10-10-2003, 02:37 AM
i've "heard" this as well. I personally am unsure if the valves would clear the non-valve-relief'd pistons. A friend of mine is swapping a d16a6 into his HF, so its a project that we're going to try.. swap a 16v head onto the d15b6 block and turn it over manually to see if the valves hit..
