Go Back   Automotive Forums Car Chat > GMC > Envoy
Old 11-19-2008, 09:27 PM
k101683 k101683 is offline
Windshield Wipers Anyone?
My windshield wiper pump is malfunctioning. When the switch is activated to start the flow from the windshield wiper fluid reservoir, the pump doesn't make the humming sound which led me to believe it was the pump that needs to be replaced. Replacing the pump didn't help anything and the line wasn't clogged. I am going to check to see if there is 12V supplied through the line, but what do I do if there is not?? Better yet, what do I do if there is? How much could this cost me or is this something I can do by myself?
Old 11-20-2008, 12:32 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: Windshield Wipers Anyone?
If you don't see 12V at the plug when you press the washer button, check the ground wire from the pump for a good connection. Then trace back the power wire to check for cuts rubs or breaks. And of course, check the fuse for that circuit.
If you DO see 12V, then it's possible, though unlikely, that you got a bad pump. OEM is recommended here over a "universal" type which just don't have the reliability.
If you see voltage but not 12V, then check your battery, alternator, and grounds again for good connections and no corroded or fatigued spots. Good luck!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
