Old 11-19-2008, 05:06 PM
babijv babijv is offline
PCM question
Would a bad Powertrain Control Module (PCM) cause the alternator not to charge a full charge.My alternator started to charge, after I cleaned the grounds but the charge is not enough to even turn the lights on.Thank you for the wiring harness, this is still the same car. 96 Grand am 2.4L
Old 11-19-2008, 07:10 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Re: PCM question
Actualy your GA has a ECM/ECU which is not always reffered to as a PCM.
Yes a bad ECM can under or over charge your battery, though it could be something else.
I would double check your connection, make sure they are all tight.
1999 Grand Am SS 3.4 OHV
