Old 11-18-2008, 11:42 PM
Firebird1 Firebird1 is offline
Send a message via AIM to Firebird1
Tool to remove lifters (valve lash)
Hi
Do anybody out there know where I can buy the tool to compress the valve springs in order to remove the lash (lifters)??? My car is ticking like a loud watch. I don't won't to used the screw driver method cause know me I miss and scratch something and then I am really screwed Thank you.....
Old 11-19-2008, 06:51 PM
toddrs93's Avatar
toddrs93 toddrs93 is offline
Re: Tool to remove lifters (valve lash)
most auto parts store have valve spring compressors, however I would not do it that way. Still to risky, in my opinion, though many people have successfully done it. I personally just think its kind of shady. I take the extra time and just pull the timing belt off, and take the cams out, then the lifters. It really does not take much longer, and its better to do it right. Might as well replace that timing belt and tensioner at the same time as well.
Old 11-19-2008, 07:26 PM
I thought about that, but wasn't sure Thanks. But how do you line things back up? Or do you just mark things before you take them apart???
Old 11-19-2008, 08:58 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
www.stealth316.com
Use it, learn it, love it
Old 11-19-2008, 09:01 PM
95DodgeAvenger95's Avatar
95DodgeAvenger95 95DodgeAvenger95 is offline
Send a message via AIM to 95DodgeAvenger95
well its pretty strait forward how to line every thing back up the tricky part is just having enough hands to set the cams in time, i made some cam locks outta like a 3 inch bolt and 4 washers (2 on upper part of cam and 2 on lower side of cam) and just put a nut on the end of bolt and lightly tightend them up so the cams wouldnt slip. then the crank is easy to line up theres a mark on the block that u match up with the crank, there is a write on on stealth 316 very useful. then when u put the T-belt back on MAKE sure i repeat MAKE SURE the belt is tight all around and ull have to buy the tensinor tool or get creative, i just used vise grips and a heavy duty staple and bent it to fit the holes to tighter it up. and then when ur all done turn the motor over by hand about 6 or 7 times to make sure ur not hitting the valves with the pistons.
Black 96 3000Gt Vr4 58k mi, H.H.H. Data logger, RPS MAX, Big16G/14b Combo, FMIC, AEM EUGO, Greddy EBC, SAFC II, 560's, hotwired 255lph, not cats, Solid motor mounts, Faze boost gauge, Apexi turbo timer, full exhaust with 3" ICH Single shot Catback, K&N Air Filter, Front upper strut brace, T-Case Bracket, AC delete, Meth injection, NGK stg 1 colder, 8k HID'S.
AIMING FOR 500+AWHP at ips dyno.
