Old 11-18-2008, 11:42 PM
rscamaroboy89 rscamaroboy89 is offline
key wont pop trunk
on my gtp my black key thingy lol,wont pop the trunk.it unlocks the doors fine,and the popper in the dash works fine.if i push the trunk button you can hear a click under the dash on the driver side but it never pops,anyone know how to fix this problem? if so id much appreciate it thanks.
my car 1998 grand prix gtp,borla catback exhaust,fwi,u-bend delete,resonator delete,
180 t-stat,zzp 1.0 pcm,zzp poly motor mounts,zzp shift kit,3 inch high flow cat,3 inch cutout.
not installed:zzp 3.4 mps,autolite 104's
next to order:headers with 3" downpipe
Old 11-19-2008, 01:19 AM
doctorhrdware doctorhrdware is offline
Re: key wont pop trunk
Sounds like the contact on the key fob for the trunk is bad or dirty. You can use a pencil eraser on the circuit board to clean the contact. If that does not fix the problem it might be time to replace the key fob.
Old 11-19-2008, 10:01 AM
ok thanks ill give it a try.if i need a new one where do i get one? from the dealership?
Old 11-19-2008, 12:30 PM
rkvons's Avatar
rkvons rkvons is offline
I would think that if he hears a click under the dash when he presses the trunk button on the FOB, the FOB is doing its job. But maybe I don't understand. Also, if it does end up being the FOB, I have purchased several off of ebay and have been quite happy with them. Dealers want too much.
Old 11-19-2008, 12:33 PM
rkvons's Avatar
Do you have a button in your glovebox to pop the trunk? And does that work?
Old 11-19-2008, 03:32 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
see post #1, OP stated the glove box button works. I would say it's either a BCM issue or weak/bad relay.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 11-19-2008, 11:41 PM
cleant it was very dirty,but it still doenst work just clicks.the clicking under the dash makes me think its a relay.does anyone know which one under there works the trunk?
Old 11-20-2008, 08:19 AM
richtazz's Avatar
IF you still have your owners manual, you're going to have to check it for the relay position in the fuse box (or check to see if your fuse box still has the legend sticker on the cover), as they vary from year to year.
