Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 11-18-2008, 08:01 PM
tom palmer tom palmer is offline
How To Replace A 1999 Suburban Interior Left Front Door Handle
Have An Old 99 Suburban Need To Replace Left Interior Door Lock How Is It Done
Old 11-19-2008, 08:05 AM
j cAT j cAT is offline
Re: How To Replace A 1999 Suburban Interior Left Front Door Handle
is this the door handle or the lock mechanism....?
the fragile handle on the interior is ,,,just remove door panel and unbolt..
Old 01-02-2009, 10:30 AM
Fabshop Fabshop is offline
Since we too needed to know how to remove the door panel to get to the handle for replacement, I thought I would update the help requested.
To remove the door panel, look between the panel and the door frame itself using a flat head screwdriver to lightly pry it up, and look for the white plastic panel clips (they are like prongs with barbs). Put the screwdriver between the two heads that you will see with a rag on your doorframe (so not to scratch it) and carefully pry them apart. Repeat this procedure about 8 times around the bottom of the door panel and around the sides. Once these are all released, lift door panel up with window seal and it should come right off.
That's how you get into it without breaking all your clips. Hope this helps others that searched all over the internet and only got the same stupid answer to just remove the panel.
Racing IS life, everything else is just waiting.
Old 03-05-2009, 10:12 AM
sniper4x4 sniper4x4 is offline
Send a message via Yahoo to sniper4x4
Your also going to need to drill out the 3/16" Pop rivet holding the old handle in place & I would recommend replacing the rivet since it holds the handle base in place.
Toys:
11' Camaro RS
99' GMC Suburban 10" lift
00' Mustang GT Conv.
07' High Jumper Sandrail (For Sale)
My favorite Toy 73 Kona 463 Olds
