Old 11-17-2008, 06:43 PM
big1521truck big1521truck is offline
school bus question
im working on a 84 model thomas built school bus and the problem that is occuring is that when it is put in gear the motor stalls and turns off. it is an automatic tansmission and im thinking it might be the locking torque converter? any input or advice on how to diag this problem further would be greatly appreciated...
thanks__thomas
Old 11-17-2008, 06:50 PM
maxwedge maxwedge is offline
A990 racer
Re: school bus question
Would be nice to know what engine and trans it has and does it stall in drive and reverse, and does this trans have a lock up convertor, lots of info is missing here!
Old 11-17-2008, 07:25 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Thomas was the coachbuilder that built the body and interior. The chassis, suspension, engine, trans etc were all built by a truck manufacturer. We would need to know what maker that is. Likely the grille, hood etc should have the maker's name.
Old 11-17-2008, 08:40 PM
it is a detroit diesel motor...possibly an allison transmission...ford made the chassis...i will find out more info tomorrow...im from north carolina but im in haiti doing some work at a school but they are having some problems with this bus and im trying to get it straightened out...thanks for all the help!!!!
Old 11-17-2008, 08:42 PM
yes it does stall in reverse and drive
Old 11-19-2008, 02:24 PM
A990 racer
If it is just not a normal stall condition that can be adjusted by setting the idle speed, than something is locked up in the trans.
Old 11-19-2008, 09:07 PM
it is running fine at idle it just boggs down and stalls when put into gear...i was thinking it could be the toqrue converter clutch is staying engauged but im not really sure...thanks for the help
