Go Back   Automotive Forums Car Chat > Geo > Nova | Prizm | Spectrum | Sprint
Old 11-17-2008, 05:47 PM
chris strue chris strue is offline
geo head lights
Have 1992 geo prizm head lights work only on high but idecator light for that does not work. I have replaced switch under steering wheel still the same. All fuses are good but still nothing. all other lights work fine.
Old 01-15-2009, 10:58 PM
f1drivr f1drivr is offline
Re: geo head lights
I have the same problem. Did you you get it fixed?
Old 01-28-2009, 07:07 PM
Re: geo head lights
OK, I have a temp fix. I installed a new GND wire on the right side headlight. It's connected to the center wire on the headlight plug and I ran the other end to the car frame. Now the headlights work in hi and low, but the indicator on the dash doesn't work.
Old 01-29-2009, 09:04 PM
blindeyed's Avatar
blindeyed blindeyed is offline
eBay aDdict™
Send a message via AIM to blindeyed
Re: geo head lights
Have you tried replacing the bulb in the cluster? Could be burnt out.
- Jason
1995 Pontiac Firebird
User Guidelines | VB Codes Explained | AF Merchandise
"Each of us, is in the scheme of things, insignificant.
But millions of insignificant people, doing a tiny bit,
can add up to be a very significant force."
Old 02-01-2009, 11:50 AM
Re: geo head lights
I check the bulb last night, it's good.
