Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 11-17-2008, 05:14 PM
procrstinator procrstinator is offline
fuel problem
93 eclipse 2.0 car sat for nearly 5 yrs. Tow yard picks it up off some property. My girlfriend in Florida gets a lean in progress letter about the car she sold 5 yrs ago!. Apparently she has been the regesterd or not owner all that time . Anyway, she goes to bail it out and finds out one of the workers there had been cranking the engine the day before and drained the battery. Yeah , thats what i said .. Of all the stupid , idiotic things to do ..Because of that i told her to tell them that now they can pull your tank and put a new pump in it , They probobly just cleaned the screen , i dont know . So they supposedly cleaned the tank. Then i couldnt exspress enough to make sure to change the fuel filter and blow that bad shit out of the fuel rail. Im thinking its to late and that 5 yr old crap is sitting at the injectors clogging up and restricting the flow because she says it will run ok if she taps on injectors when its running. shes been trying to get the fuel fiter off but its hard to get to . Any advice on that fuel filter and any other thoughts on what should have or will need to be done after sitting that long ? Thanks in advance for your help..
Old 11-18-2008, 07:59 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: fuel problem
Clean the fuel system, injectors, change the fuel filter and change the gas and see how it runs.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
