Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 11-17-2008, 05:09 PM
Scrapper Scrapper is offline
AF Premium User
thunder bird
i don't get into changing moters but a guy changed the moter for my niece. first of all they heard it run before buying moter.now it don't idle right the sterring wheel vibrates to.the guy changed timing a couple of times with no luck.anyone out there thats had this trouble? she needs this car for work and it has the 3800 piece of junk they have weak trannys to.
thanks
scrapper1
Old 11-18-2008, 02:48 PM
Frat-man-du's Avatar
Frat-man-du Frat-man-du is offline
Re: thunder bird
What year T-Bird.
This could be as simple a vacuum leak from a hose that didn't get connected or was broken during the install. It could also be bad timing, bad plugs, wires, etc.
Did the installed put new spark plugs, fuel filter, PCV valve and plug wires (if so equipped)?
1964 Austin Healy 3000
1965 TBird Coupe -Show
1965 TBird Vert - Show
1978 Lincoln T/C 460 CID -RIP
1985 TBird Fila -Show- sold
1990 Lincoln T/C 5.0 - RIP
1995 Lincoln Mark VIII - RIP
1997 TBird LTD -RIP
1998 Lincoln Mark VIII LSC
2000 Mustang Vert
2003 Expedition 5.4l EB
Old 11-18-2008, 05:30 PM
97Bird's Avatar
97Bird 97Bird is offline
Re: thunder bird
Also be sure the plug wires are connected properly according to the firing order.
The Original 97Bird
