Old 11-17-2008, 10:47 AM
Buried.Alive Buried.Alive is offline
Driver Side Door Lock
Ok i purchased this 2002 Sunfire in August and when i bought it the driver side door was tricky to unlock from the outside with the key (no automatic locks) So it is now November and it will not unlock at all. It is not the key because it works in the passanger side lock just fine along with the trunk. I asked a mechanic and he said to put a crap load of lube in it and it should work. I did and it worked for about a day. The next day when it stopped working again i put more in and it will not work at all. Does anyone have any idea what could be wrong... And how to fix it?
Thanks
Old 11-17-2008, 06:09 PM
Classicrocjunkie's Avatar
Classicrocjunkie Classicrocjunkie is offline
Lifted GMT-360!
Send a message via AIM to Classicrocjunkie
Re: Driver Side Door Lock
I've got the same problem with my 04 sunfire right now with auto locks.
It doesn't like the cold weather for some reason. When temps are above 40's it works fine, but in the 30's it never unlocks right away. What are you lubing it with? I would suggest some graphite. I have just been too lazy to do anything since I drive my car maybe 6 times a month while at college.
Please don't PM me with your J-body Issues. Post appropriately in the forums,
and I will toss my opinion in your thread if I have anything to help. - Thanks!
2006 Chevrolet Trailblazer
2010 Glastron GT 205XL
Old 11-17-2008, 07:57 PM
Hungrycat7's Avatar
Hungrycat7 Hungrycat7 is offline
Sounds like that cylinder needs replaced. Could be a problem with the lock rods as well. I would suggest removing the door panel and examining it from the inside. Disconnect the lock cylinder and see if you can unlock the door with the lock rod. If that goes smoothly it would be a pretty good indication you need a new cylinder.
