Go Back   Automotive Forums Car Chat > Oldsmobile > Silhouette
Old 11-17-2008, 09:12 AM
jymkym1 jymkym1 is offline
97 silhouette power seats & door not working
i have a 97 and the power seats and power sliding door just quit working, checked fuses, tried reseting the door.... any thoughts would be helpfull
Old 11-18-2008, 04:14 PM
463's Avatar
463 463 is offline
Re: 97 silhouette power seats & door not working
circuit breaker is a 30 amp for the powerseat/power door is not working or the power to it is fused under the hood in the fuse box called main fuse #2 also check the rear defog and the auto air level control/air pump if you have the options as the power is shared from that #2 main fuse.
Old 05-27-2009, 09:10 PM
danpletch danpletch is offline
I have a '98 that had both front power seats stop working, but none of the fuses were blown. I read somewhere on here that there was a main wiring bundle that came down from the passenger's A-piller under the dash, under the carpet. I turned my carpet over and pulled it back to the first seat. I found that the connection for the power or ground wires were completely corroded. Too much coffee spilt or something.....Once I cleaned the wires and soldered a few joints...good as used....or at least the way things were before they stopped working...good luck
