Go Back   Automotive Forums Car Chat > Cars in General
Old 11-16-2008, 07:25 PM
luxeryvic luxeryvic is offline
compression ignition
ok, i know diesel engines are more effiecient because of compression ignition results in a more complete burn of the fuel but y dont gas engines run on compression ignition? would it not be the same as diesel if the compressio ratio was raised to the right ratio?
Old 12-30-2008, 01:50 AM
oldblu65's Avatar
oldblu65 oldblu65 is offline
Question Re: compression ignition
Gasoline engines run on spark ignition , not compression ignition . Because diesels run such high compression, they have to be built of much stronger materials than gasoline engines . To run a gasoline engine with the compression ratio of a diesel would require a super high octane gasoline and I don't think there exists any such a blend . Also , the gasoline engine would require such extensive strengthening modifications that it would not be economically viable to do so . The diesel engine can be easily modified to not only outperform the gasoline engine , but it also will get better mileage !
