Go Back   Automotive Forums Car Chat > Cadillac > Deville
Old 11-16-2008, 04:21 PM
Johnsmail987 Johnsmail987 is offline
2000 Deville electrical a/c help!!
I have a 2000 deville with no power going to the compressor.
The A/c relay is good but no signal to throw relay to close position.
Fans stay on at low speed all the time with key on.
Low pressure A/c switch has power and it has 2 high side switch with no power going to them.
Old 11-16-2008, 05:51 PM
brcidd's Avatar
brcidd brcidd is offline
Re: 2000 Deville electrical a/c help!!
So is your "service A/C soon" message on -- on the display? If so you have an a/c code set and it needs to be reset so that the compressor can be commanded on- either do it on the display, use a scan tool- or unhook the battery for 10 seconds if you have the low charge code-Then you'll need to find out why the low charge code set-- most likely a leak somewhere- if any other sensor type code exists, (under the ACM codes) then you'll have to fix the sensor- because those come back immediately, and the compressor is automatically shutdown...the computer controls the relay- and it will never allow the compressor to run if there is a code set.....
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 11-16-2008, 08:40 PM
How do i use the control to see what code is present? I unplug the battery . no luck , do you think the orfice tube maybe clog? or can i bypass the Ac sensors?
Old 11-17-2008, 04:17 PM
brcidd's Avatar
Turn ignition on- hold the "off" and "warmer" buttons in at the same time for at least 5 seconds until the diagnostic scheme comes up- use the fan speed "higher" for yes and "lower" for no - when it asks you the questions- you are looking for the ACM codes- should be a 4 digit code- and you can reset it when it asks you....you cannot bypass this system and still have a properly working system- I have had to "unbypass" several botched cars-- one would not shut the engine off for about 10 seconds because of a brainless bypasser....
'99 GMC Yukon
