Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 11-16-2008, 11:47 AM
Sigma6 Sigma6 is offline
No power windows or locks from driver side
I was replaceing the drivers window because the clips that hold it broke. 3 days later when new window came in, now power windows nor locks work from drivers control panel. I checked 30 amp breaker. everything else works. All windows work at their individual power switch, except drivers.
Any Ideas???
I cannot find wiring diagram for drivers window control panel.
2007 Chevrolet Silverado
1997 Izuzu Rodeo LS 4WD
Old 11-16-2008, 01:49 PM
chaswe75 chaswe75 is offline
Re: No power windows or locks from driver side
I assume you mean 30 amp breaker as the one with the little push button reset located in fuse panel on side of dash. Check the regulator/window motor wire and make it sure it isn't pinched between window parts. Make sure terminals on wire plugs aren't bent. I replaced both window motors on front windows for my rodeo rather than get ripped on buying the whole assembly and it was a pain in the ass. Isuzus are not the most DIY friendly vehicles. Last resort, get a multimeter and start testing for power.
Old 11-16-2008, 06:30 PM
Cat Fuzz Cat Fuzz is offline
Since you've been fiddling around inside the drivers door the obvious place to check is inside the drivers door. You may have pinched or broken a wire inside the door or it could just be coincidence and the break might be where the wires leave to door and go into the body. This is the most logical place to look.
Old 11-17-2008, 10:05 AM
I found no pinched or broken wires inside door. I am getting 12vdc to grn/red wire from "power window Relay". I am reading 3.75 vdc on several other pins going to drivers side control panel. I opened control panel on driver side door, it looks like it has some corrosion on it from water. Any idea where I can find a new one and how much???
Old 11-19-2008, 11:36 PM
Take the passenger window & lock switch and at least plug up the door lock switch plug to your driver's side. The window switch plug is a double so it probably won't work, but the lock switch will. Then you know the switch is most likely bad if you are getting juice from the relay. Check the salvage yards or you might get lucky on Ebay.
