Go Back   Automotive Forums Car Chat > Cadillac > Catera
Old 11-16-2008, 11:16 AM
LoMbArD LoMbArD is offline
Disable drivers side airbag?
How can you disable the drivers side airbag in a catera? My mother in law's caters is having some steering column clicking sounds. it is intermittant. a mechanic told her that it was possible that the issue in the steering column would likely cause the airbag to deploy and is wanting to charge her a TON to get it disabled. I'll be going over to visit her in a couple weekends and if I could disable for her to save her some money that would be great. Is it as simple as removing a fuse?
TIA
Lombard
Old 11-16-2008, 03:25 PM
maxwedge maxwedge is offline
A990 racer
Re: Disable drivers side airbag?
Don't believe the air bag may deploy story, the clicking would normally not be related, get a proper diagnosis. You can find the connector for the air bag usually at the bottom of the steering column, this is not for a dyer to play with.
Old 11-17-2008, 10:14 AM
I used to do all her work for her until my wife and I moved out of town about 5 years ago. . .since then she has found a mechanic, and from the stories she tells I don't know how reliable he is. I'll have her get a second opinion on it.
Thanks.
Old 11-22-2008, 09:23 PM
dugan50's Avatar
dugan50 dugan50 is offline
Authorized Vendor
Disabling an airbag system is both dangerous for some owners (drivers) and necessary for others. The guidelines set forth by the government will outline who qualifies for this procedure and why it may be necessary. There is much information on the safety concerns and the dangers involved in disabling these systems. Check out these quick movies and website to understand the importance of airbag safety.
http://www.airbagsolutions.com/movie9.aspx
If after you watch these videos you still want to disable the safety system on your car, here is the next step for you to take. Get permission to do so from NHTSA through this link…
http://www.airbagsolutions.com/resources1.aspx
(first section marked ‘Airbag On-Off Switch Request Form”)
Once you obtain the permission form, you can legally disable the system. Interrupting the power circuit will render the airbag system inoperative. Most vehicles have a fuse marked ‘SRS’, SIR’, or ‘Airbag’ in the main fuse block. If that is removed, the light will illuminate indicating the system is inoperative and none of the supplemental restraints will deploy if involved in an accident.
This information is provided by http://www.airbagsolutions.com
I hope this was helpful to you. My information comes from years of experience in these businesses.
http://www.airbagsolutions.com http://www.stolenandrecovered.com
Airbag Service, Airbag Replacement, Airbag Diagnostics
Thank You,
Douglas Gan
