Old 11-16-2008, 02:24 AM
tonypuka tonypuka is offline
high idle on cold start
Since it has gotten colder up here in Minnesota, my 1995 LeSabre on cold start,idles extremely high. If I try to drive it , it chugs,misses,lurches.Once the motor warms up, idle is normal. When the engine is warm , on start up it idles normally.
Any Feedback is appreciated. I could move to Hawaii where its warmer,then no cold starts anymore.
Old 11-16-2008, 08:07 AM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: high idle on cold start
Have you cleaned the idle air control (IAC)?
Old 11-30-2008, 11:08 PM
I will give that a try,,,thanx
Old 12-01-2008, 11:19 AM
Ralph50 Ralph50 is offline
I found this issue on my 96 Lesabre, follow the vacumm line from the brake booster to the UIM. There is a plastic fitting that goes into the UIM. This fitting has an O Ring that might have lost its shape. When I checked mine the O Ring was not larger than the dia which it is meant to seal. This could result in a vaccum leak which will rise the RPM.
