02 Explorer clicking
My 02 Explorer has a very annoying clicking sound comming from the left rear of the vehicle, it only happens sometimes though, I think it has something to do with the rear A/C. Any Suggesions??
Re: 02 Explorer clicking
There is an actuator in there that may be failing. Remove the panel and look for it.
Being way2old is why I need help from younger minds The sooner you fall behind the more time you'll have to catch up. ![]() HEY Y'ALL--READ THIS Here are some of our old vehicles for sale.
What exactly am I looking for?, any pictures?
Here ya go. Directions and drawings from the manual. Hope it helps.
Auxiliary Temperature Blend Door Actuator — Air Distribution Removal and Installation Remove the LH quarter trim panel. Disconnect the wiring harness. Disconnect the electrical connectors. Detach the electrical connnector pin-type retainer. ![]() Disconnect the vertical air duct from the auxiliary climate control housing. ![]() Remove the bolt. ![]() Remove the bolt. ![]() Remove the nut and position the auxiliary climate control housing away from the quarter panel. ![]() Remove the air distribution blend door actuator. Disconnect the electrical connector. Remove the screws. Remove the air distribution blend door actuator. ![]() To install, reverse the removal procedure.
Way2Old, is there a blower motor in the rear of the '02 Explorer as well, near the actuator? If there is, I'm wondering if the noise could be something in the blower motor squirrel cage.
-Rod |
There is a blower motor there also. When the trim panel is removed, the poster can determine exactly where the clicking is coming from. The most common failure is the plastic gear inside the actuator not allowing the motor to shut off. Just tries to keep moving the lever.
Thanks Guys I will be opening and investigating ASAP, I will let you know how it turns out.
