Go Back   Automotive Forums Car Chat > Buick > Century
Old 11-15-2008, 05:32 PM
norurb norurb is offline
1988 Century stuck in Park
I replaced the TPS on my dad's Century, 2.8 motor. Immediately afterwards, the car would not go either forward or reverse. It feels as though there is a wheel chok holding the car in place. What could have happened? I triple checked every connection. I also took a look at the throttle cable and related pulley. I don't get it. Has anybody experienced this?
While I was checking the car, I pulled the idle air control valve. It is very hard to push in or out. Is this normal?
Old 11-17-2008, 08:40 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: 1988 Century stuck in Park
Does the shifter move or is it stuck (like maybe you dropped a socket or something that has the shift linkage bound up)? Other than that, I see no way changing a TPS could cause this car to not shift out of park.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 11-17-2008, 09:45 PM
stripe stripe is offline
when you step on the brake you should hear a servo move in your steering column.
Likely you unhooked the wire to the brake stuff.
Or there is a neutral position sensor that is not right.
Cheers
Stripe
Old 11-20-2008, 11:24 AM
richtazz's Avatar
Cheers
Stripe
An 88 Century has no brake/shifter interlock. That's a safety feature not implemented until much later.
Old 11-20-2008, 08:56 PM
Thanks
I never had a 88."year"
Cheers
Stripe
Old 11-20-2008, 09:02 PM
Thanks
Cheers
Stripe
buick that is lots of 92's.
cheers
Stripe
