Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > Engine and Transmission
Engine and Transmission Discuss Engine, Transmission, and all other performance modifications here.
Old 11-15-2008, 03:26 PM
jason-1995fbody's Avatar
jason-1995fbody jason-1995fbody is offline
junk 305 or not
got a car that has a 305 in it not much on it just the heads and oil pan any way so for the hell of it i looked up the casting numbers and found this
http://www.chevytech.com/3c14014416.html
sounds like a good find for free i will be porting them installing new springs seals and pin in the studs
what do you guys think
1989 camaro iroc 350 bored .060 over aluminum intake q-jet unknown big cam 194/150 valves ported and polished automatic /shift kit
93 accord 4 door auto stock
Old 11-15-2008, 07:43 PM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
Re: junk 305 or not
as long as they aren't swirl ports.
Old 11-17-2008, 02:16 PM
MrPbody MrPbody is offline
AF -Advisor
Re: junk 305 or not
416s are decent heads for a 305. I wouldn't want them on 350... 327? Maybe...! With some judicious port work and larger valves, this head can make good power.
We try to steer people away from "pinning" heads anymore. It "works", but if you have any trouble with the stud down the road, you're in big trouble. If you're adding heavy valve springs, that usually means a bigger cam. That calls for "screw-in" studs and pushrod guideplates. Any good machine shop can install them for less than $200. "Pinning" is something "left over" from the 1960s.
Jim
