Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 11-15-2008, 12:50 AM
RJLipscomb RJLipscomb is offline
Unhappy 01 Fan Speed Control
My 01 Fan Control does not work on speeds 1 and 2. Where is the fan control resistor block located?
Old 11-15-2008, 01:07 PM
j cAT j cAT is offline
Re: 01 Fan Speed Control
this is another gm designed to fail item...the resistor circuit board is located next to the blower motor...this is under the glove box..
you will see wires and a connector remove mounting screws and install a new aftermarket resistor pack...also MAKE SURE THAT THE CABIN AIR FILTER IS CLEAN/REPLACED.....air restrictions will cause this resistor assy. too fail sooner...removal of the filter wil cause a/c to stop working effecently...
this is easy job..
