Old 11-14-2008, 11:10 PM
sgbuick sgbuick is offline
Rear spring compatibility
Has anyone used 91-96 springs on a 97 or later model? Will they fit? There are 2 reasons I want to do this: 1 to get a softer ride and 2 because they are much easier to find in salvage yards. There only seems to be 1 aftermarket rear spring available new and it's impossible to tell if it's the stiff riding (Grand Touring) or soft riding (Dynaride) ones.
Old 11-15-2008, 05:14 AM
ZiggyPA ZiggyPA is offline
Re: Rear pring compatibility
In my topic about the grand touring suspension a couple of weeks ago, there is a link to another topic about this.
Old 11-15-2008, 11:31 PM
Re: Rear spring compatibility
ZiggyPA, I checked the other post but my main question is whether the newer redesigned model P/A (97-2005) and Lesabre (2000-2005) can use the same rear springs as the earlier ones (92-99 Lesabre and 91-96 P/A). Thanks.
Old 11-24-2008, 02:57 PM
TopherS's Avatar
TopherS TopherS is offline
sgbuick, Sorry I can't help you on this, but if you do find out, please post what you find. I would like to know the same thing...I've been wanting a softer ride from my 01 PA. I was thinking more about replacing the front springs on mine, but I don't know if they'll work. I could see replacing all four, if they'd work...
Topher S
Portland, OR
2001 Buick Park Avenue
2006 Chrysler Town & Country Limited
Old 11-28-2008, 06:53 PM
Tophers, same here, it is frustrating to see only 1 moog spring listed as being available (on Advance Auto parts website, as well as the local parts stores) and then on the Moog website with all the details (rate, etc.), that spring is not even mentioned on the list. Here's the moog website in case anyone's interested:
http://bbb-carb.com/moog_Coil_Springs.htm
Old 11-29-2008, 02:35 PM
Jrs3800 Jrs3800 is offline
You will not be able to use the 91-96 Park Ave springs as the 97+ went to the newer platform...
If you had a 96 I could easily tell you what to get to make it a mean handling Buick..LOL
You might want to check the compatibility of parts between the Park Ave and the 00+ Bonneville SLE, SSEi and GXP... I believe that these were built on the same platform but can't say for certain..
we would need to be able to compare the spring specs between them but as of yet I have found nothing that will show me the specs...
At one point there was a Site I used to look up a lot of various spring specs... The site has changed
