Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 11-14-2008, 08:01 PM
renchhednot renchhednot is offline
1995 Cutlass Supreme LS steer issue
Hi all especially mpumas, scrapper, and max. This is the same Cutlass as my last post. Ok, the car starts out driving down the road smooth and a few miles later it started feeling like there was a rumble coming from the left front. Again, my "mechanic" friend told me he thought it was the rotors. It feels like you are going over a rumble strip, then it quits and rides smooth for awhile again. Could this be a CV joint? Thanks everyone!
Old 11-15-2008, 07:35 AM
maxwedge maxwedge is offline
A990 racer
Re: 1995 Cutlass Supreme LS steer issue
Could be anything, make sure the caliper and bracket are tight, also the retaining bolts for the axle to output shaft, someone has to road test the car and carefully inspect all the related components.
Old 11-25-2008, 02:14 PM
Thanks max- This problem I have solved with new pads all the way around and new rear rotors. Now I have the issue with the ABS light staying on.
Old 11-25-2008, 02:15 PM
oops - that is new rear calipers
Old 11-25-2008, 02:52 PM
A990 racer
Look for loose, frayed ,corroded connections at all 4 sensors and wiring, a scan with an abs function scanner would pinpoint the problem.
