Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 11-14-2008, 04:14 PM
NateS's Avatar
NateS NateS is offline
Send a message via AIM to NateS
Disconnecting EVAP and EGR
Okay so I was scoping out my vacume lines the other day and noticed that my EGR and EVAP sensors were on vacume circuits of their own. So, I unplugged the sensors and blocked off the vacume lines. The car runs fine although of course it has thrown a CEL for the EVAP and EGR. I know alot of people do this mod but, do you also have to remove the EGR valve and EVAP system along with disconnecting them? I know they sell an EGR block off plate but the car seems to be fine without removing and blocking it off.
Oh and I also noticed that before I did this my boost gauge needle was very shaky while boosting. Now it is dead on no shake. I assume there might have been a slight leak somewhere in the EVAP/EGR circuit.
95 GSX 5 speed
2.3L stroker bored .020 over
Built head
Bullseye/Borg Warner T04B 57 Trim Turbo
RNR 3" turboback w/ o2 eliminator
255 lph Extreme Motorsports fuel pump
Extreme Motorsports mbc
SAFC
Greddy Type S BOV
FMIC (core 28x10.5x3.5)
FIC 650cc fuel injectors
RK Sport Fuel Pressure Regulator
My Car Domain
Old 11-14-2008, 05:10 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: Disconnecting EVAP and EGR
You can leak it the way you have it of remove them completely. Most people dont want the EGR because it puts carbon into your intake system. Unplugging it will disable it and it will no longer work. If it doesn't work no need to leave it on the motor so people remove it and use the block off plates. Gets rid of some of the clutter in the engine bay but other than that you can leave it on. I made my own block off plates in about an hour or so. So thats an option if you dont want to spend the $20 for them.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 11-14-2008, 09:12 PM
NateS's Avatar
So basically, the way I have it set up right now is fine but, not optimal. I could do a write up with pictures on how to simplify the vacuum lines and cut down to the bare necessities if you guys think it would be useful.
95 GSX 5 speed
Built head
SAFC
Greddy Type S BOV
My Car Domain
Old 11-14-2008, 09:33 PM
Holset powered 420a
The way you have it now is just as good as if you completely removed it, just still junks up the engine bay.
98 Eclipse GS Turbo
2001 BMW 325i - DD
