Flashing brake light.
I have an 89 Astro. I have a with my brake light on my dash. The light is flashing what looks like a code. I don't have ABS on the van. The code is 1 long flash and 9 short flashes. This code repeats over and over. I have tried looking this up and can't find what it means. I hope someone can tell me what it means.
Thank you. |
Re: Flashing brake light.
You say you don't have ABS - but I'll bet you have rear wheel ABS- you are flashing a code "9" which means there is a circuit fault with the rear wheel ABS-
Measure your voltage between pins "A" & "H" on ALDL (diagnostic plug) connector at base of dash- if voltage is "0" then most common reason for flash is a blown DRAC/cluster fuse- If voltage is 8-15 volts then check for open circuit in rear wheel speed sensors- which I believe on your van is at the drive shaft - Has any brake work been done? bleeding the lines? how about rear wheels- I have had this happen where the master cylinder was replaced- and the code appeared- and the mechanic forgot to reset the code- with his scan tool...
Automotive A/C Engineer with: '99 IH 4700 Toy Hauler (2) '95 GEO Prizms both maroon '99 GMC Yukon '95 Chev 3500, 454 Dually Crew Cab- 145k miles- Wife's Camel trailer puller. '94 Astro- 370k miles '94 Firebird Formula- 5.7L 180k miles- gone- '92 Chevy Lumina Van 3.8L 264k '86 GMC S-15 - 2.8L 154k '87 Buick Park Ave . 187k '86 Buick Park Ave 3.8L 199k miles- gone '77 Chevy Vega- 2.5L 175k miles gone but not forgotten '68 Camaro 396 4 spd RS/SS -72k miles- |
I don't have rear ABS ether. I don't have any sensors on the rear wheals at or at the drive shaft.
What about the sensor on the rear of the transmission or transfer case?
Permanent seat assignment on the Group W bench... Automotive Forums Survival Guide |
