Go Back   Automotive Forums Car Chat > Lincoln > Town Car
Old 11-14-2008, 02:53 AM
V8-dreams V8-dreams is offline
Vehicle is not responding 2005 LTC
Hy guys,
want check my codes on my 2005 LTC and my Autoxray scanner always
say " vehicle is not responding " .
Updated my scanner with the 3.03 Software.
Someone has an idea
THX Oliver
Old 11-14-2008, 10:42 AM
Psman32@af Psman32@af is offline
Send a message via AIM to Psman32@af Send a message via Yahoo to Psman32@af
Re: Vehicle is not responding 2005 LTC
Is that what the scanner says when you hook it up to try to scan the OBD2?
2005 Mercury Grand Marquis. 230 WHP 249 ft-lbs as measured by a mustang dyno.
Old 11-14-2008, 02:45 PM
Yes , that is what the scanner say
Old 11-15-2008, 12:06 PM
At the moment, I cant think of any reason it would say that. Do you know anyone who has a different scanner you can try? Or is there a auto part store around you where you could try theirs to see if you get a different response.
Old 11-16-2008, 02:49 AM
Towncar's Avatar
Towncar Towncar is offline
Any other symptoms?..
Obviously the CEL is lit.. is the car running or not running?
How's the battery charge? Should be 12V minimum.
-Steven
1996 Town Car, Cartier
Old 11-16-2008, 04:25 AM
HY Guys,
First of all, the car is runnung perfect, i think only one ingnition coil is
dead.
Can not use a nother scanner, live here in southern germany( europe) and there are not so a lot of guys with lincoln.
Maybe the cable? the scanner is 6 years old ?
Thx Oliver
Old 11-16-2008, 01:18 PM
remark123 remark123 is offline
Try wiggling the connect at both ends to the car and scanner, while observing the display. See if you can make the connector work, if not you may be SOL with the scanner. It might also be the OBII connector on the car...
Old 11-17-2008, 01:22 PM
Thx for ur answer
I wiggling the connectors and nothing happens,
think i try the scanner at the mustang 2005 of my friend tomorrow,
we will see if the scanner works
Oliver
Old 11-20-2008, 06:41 AM
HY Guys,
I think i know the reason wy the scanner not work.
The Town car needs a scanner with CAN Bus funktion, i order a new scanner and we will see
Nice day
