Old 11-13-2008, 10:45 PM
mike561 mike561 is offline
Louder than normal supercharger whine
Put in a new alternator on the grand prix a few months back and ever since then the supercharger whine has been WAY louder then it used to be, sounds like its comming from near the pully, the s/c has oil, any thoughts? fyi my GP is a 98, nearing 130k miles....
2006 Chevy Cobalt LS
Old 11-14-2008, 08:09 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Louder than normal supercharger whine
Are you sure the noise is from the supercharger? Remove the SC drive belt and see if the noise goes away or changes. Also, you can spin the SC pulley by hand after the belt is removed. If the whining is from the snout then you may have snout bearings acting up.
Timeslip 08/12/06
AF Community Guidelines
Old 11-14-2008, 05:18 PM
yeah i was suspecting it may be the bearing, ill see if it still whines somewhere without the belt around the s/c pully though
Old 11-20-2008, 03:19 PM
what would be involved in removing the s/c pulley to replace the bearing(s)? i know i need a puller, any picture instructions or special tools needed?
Old 11-20-2008, 07:07 PM
BNaylor's Avatar
Did you confirm the noise was from the snout?
All you need is the SC pulley puller to remove the pulley. We have a pulley removal procedure if you use a Pulley Boys brand puller at Tips & Maintenance. Then remove the snout from the main body. Then take the snout to a automotive machine shop to have the old bearings pressed out and new installed. You can get the snout bearings and snout seal from ZZPerformance.
The other option is to replace the complete snout with a refurb or new.
Note: SC oil must be drained before removal of the snout and after work is done refill with 1 1/2 bottles of GM SC oil.
Timeslip 08/12/06
