Old 11-13-2008, 04:26 PM
soccr8stud soccr8stud is offline
Please help...
I recently changed the starter on my 2002 cavalier and i touched a wire to a medal wrench and it started to spark, didn't think anything of it so i put it back together and started just fine works. But when i was driving it around it started to sputter and my batter light came on and air bag light came on and lights dimmed on and off. IS this a problem with my computer? and if so can i reset it myself or do i have to take it to a mechanic?
Old 11-14-2008, 07:22 AM
MIke4Chevy34 MIke4Chevy34 is offline
Re: Please help...
Hi. First off, try not to put please help in the subject line. It's to generic.
Electrical problems may be better.
Anyway, I would check the ground to the motor and the power (red) wire coming from the alternator. Also, the battery connections right at the battery.
If this fixes the problem but the battery goes dead, you may have damaged the alternator or battery itself depending on what wire you shorted.
Around here, Battery sellers will do a free charging check of your system.
Good luck.
Old 11-16-2008, 12:56 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: Please help...
There is a reason the first step for most jobs is "disconnect the negative battery cable".
What's the alternator charging to? Also check the body ground if that's what you sparked to.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
