Old 11-13-2008, 03:28 PM
LeeD383 LeeD383 is offline
ABS Light On. Are codes in computer?
My 2000 SEL ABS light and Traction Control Inactive light come on periodically. Turning off the ignition will reset the lights until they come on again. My question is, are there codes stored in the computer for the problem that is occurring? The 'Check Engine' light does not come on, so are ABS codes still accessible using a standard ODBII scan tool plugged in under the dash? I don't have a scanner, but I would get one if the codes for ABS can be retrieved. Thanks.
Old 11-13-2008, 04:01 PM
catvents catvents is offline
Re: ABS Light On. Are codes in computer?
Yes the ABS codes are store in the computer however the OBD II readers will not retreived these code. ABS code readers are available but they are really costly compare to the OBD II readers.
Old 11-15-2008, 07:11 AM
LeSabre97mint's Avatar
LeSabre97mint LeSabre97mint is offline
Lee
Like catvents said the inexpensive code readers do not read the ABS and Airbag codes. I have a (borrowing, hopefully soon to be mine) SnapOn scanner. This thing is VERY COOL! It will read ABS AB and the P codes. Another thing it will tell you which door switch is keeping the dome light on so you don't have to guess. I'm sure I don't know the full abilities of this scanner. The manuals are thick.
The SnapOn scanner plugs into the same plug under the dash by the driver.
Regards
Wiswind's Windstar repair pics http://community.webshots.com/album/201931518cScpNK
Photos of my repairs: http://dansautopictures.shutterfly.com/
Check this out:http://threewheelmotorcyclemetro.shutterfly.co
A must read about problems Windstars have: http://www.automotiveforums.com/vbul...d.php?t=672854
95 Windstar 240,000+
98 Windstar 136,000+ 09-25-2008.
85 Dodge 1 Ton Snow mover gas hog
91 Mazda Protege free beater
SW MN
Old 11-17-2008, 04:45 PM
Ok, thanks for the info. I will take it to a shop and have them diagnose the issue.
Lee
