Go Back   Automotive Forums Car Chat > Isuzu > Trooper | SLX | Bighorn | Wizard
Old 11-13-2008, 03:40 PM
twcos twcos is offline
Alternator output for transmission.
under a full load what should the alt. voltage read. do i turn on radio, fan, air,lights, wipers, etc to read this. if its under a ceartain voltage will this effect trans.? what else could keep trans. from not engaging at all? thanks.
Old 11-18-2008, 01:49 PM
fourwd1's Avatar
fourwd1 fourwd1 is offline
AF -Advisor
Re: Alternator output for transmission.
You need 13.8V to charge the batt. Under a major load it might drop down around 12V, which is OK if it's only for a short time, as you're not charging the batt.
It's hard to say if low voltage will cause a problem, you didn't state what year or tranny you have.
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
2000 Isuzu Trooper + 2010 Sonata
Old 11-20-2008, 12:14 AM
Ramblin Fever Ramblin Fever is offline
YES, low volt WILL cause retarded symptoms through out the whole truck.
OUTPUT volt from alt should be nothing less then 14v while truck is running WITH accessories on, if it's less then this, it's dying.
1997 3.2L V6 Rodeo
32" Yoko's, 16x8 MB Wheels, 2" lift, Brushguard, KC Fog's, Loadwarrior Rack
On it's way to 185k strong
2004 3.4L Tacoma TRD off-road 4x4 Double cab
32" Yoko's, Westin Bull-bar, KC Fogs 60K miles
