Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 11-13-2008, 10:14 AM
bryan121476 bryan121476 is offline
Auto trans Differential check/fill???
I have a 95 camry 4cyl, automatic. I am trying to find my differential check/fill plug. I have a Haynes manual and it is not where Haynes says it is. I have looked but cannot find it...Any help??????
Old 11-13-2008, 11:52 AM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: Auto trans Differential check/fill???
Picture is in '94 Camry FSM downloadable from the sticky thread at the top of this forum. See page AX1-30.
It is directly above the drain plug on the side near the top of the differential.
Link to FSM is reproduced below:
http://www.camrystuff.com/manuals/Ge...pairManual.rar
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 11-13-2008, 12:54 PM
I will check there again...I may have missed it. Thanks
Old 11-13-2008, 01:15 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
If the FSM doesn't make it clear, on my 94 the refill plug is on the aft side of the diff facing the firewall. I want to say you can just barely see the edge of the plug/bolt from above. Not sure. Yes it's a PITA to get at. Put the drivers side on jack stands, remove the drivers side tire. Now feel the back side of the diff. It's there, it really is. I use a piece of plastic tubing stuck in the refill hole and pour fluid in from above while someone watches down below. When fluid starts dripping out the hole it's full. First make sure you lower the car till it's level.
FYI - I bought my 94 used in 99 for my daughter. About three months after buying it I checked the diff fluid level and found it nearly dry. My daughter had put 2,500 miles on it at that point (getting a ticket for doing 95 in a 70 in the process) and who knows how long it was almost dry before I bought it. I'm saying this differential is bullet proof.
Edit
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
Old 11-14-2008, 10:15 AM
Smile Re: Auto trans Differential check/fill???
I found it. It was camo'ed with all the dirt back there. THANKS
