Old 11-13-2008, 09:53 AM
tarabull's Avatar
tarabull tarabull is offline
Send a message via AIM to tarabull Send a message via Yahoo to tarabull
1990 5.7L Silverado Engine starting problem
truck has been running great till yesterday, tried to start repeatedly and it would crank but not fire, shot starting fluid under the air filter and got fire, drove to the stop sign about 100 ft away, it died, but restarted immediately.
fuel pump was recently rebuilt, but no one changed the fuel filter - we are going to do that tonite (cheapest/quickest attempt at a fix)
does anyone have any other ideas?
i don't know if this has anything to do with it (i suggested it to my husband, but he said no) coupla days ago, he went to turn on the headlights and smoke came outta the switch - hasn't happened again. any chance wires have melted together? also we recently changed the key ignition??
Old 11-14-2008, 10:05 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: 1990 5.7L Silverado Engine starting problem
Could be a loose connection in the ignition switch, which might be part of the reason for stalling. As for the headlight switch, they can and do go poof but not likely the reason for your stalling.
When you do get it going...if it feels sluggish or idles rough, it could also be the fuel pressure regulator, a clogged IAC valve or stuck EGR valve. The regulator's my first guess though.
I've also heard of problems with loose ground connections and low voltage going to the fuel pump. If this wasn't checked, it can obviously cause poor pump operation. Hope this helps!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 11-14-2008, 10:21 AM
tarabull's Avatar
thank you, will check these issues tomorrow - too dark when we get home to do anything at nite.
