Old 11-13-2008, 01:03 AM
d_rank d_rank is offline
Am I heading in the right direction?
I have a 1999 Pontiac Grand am and the power locks will not stop unlocking the doors. It only does this while the car is running and it does this in a very consistent six second intervals. This sounds similar to a problem alot of GA owners are having but it affecting there lights, dash, turn signals, and wipers. I believe my problem is connected with these but I am not able to find anything to prove this. I think that it is one of these three things; a switch is going out, a bad relay or a bad wire harness that is located behind the dash that costs appoximately $400 to replace. So if you agree or disagree please let me know because the longer I put this off the colder it gets and I will be doing this in my driveway! Any suggestions would be awesome.
Old 11-13-2008, 07:05 AM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: Am I heading in the right direction?
Welcome to AF.
I noticed you also posted the same question on the Grand Am subforum.
That subforum should generate a good response for you. Usually we discourage members starting multiple threads on the same subject.
Old 11-13-2008, 10:20 PM
Originally Posted by MagicRat
Welcome to AF.
Okay I'm sorry about that I just wanna try to solve this problem as quickly as possible before anything else starts act up, but i will not do that anymore. thanks
Old 11-13-2008, 10:47 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Another suggestion would be to follow the other forum guideline which talks to using a meaningful subject line. There are some very knowledgeable folks on these forums that will ignore threads that don't have a summary subject.
-Rod
