Old 03-18-2003, 04:10 PM
Crxce Crxce is offline
Send a message via AIM to Crxce
got the whole mpfi engine harness.
Im doing the mpfi swap and today i picked up a 91 si engine harness what do i need to do to that harness or what else do i need to do wiring wise to do the swap and do i need the new dizzy? i know i need the new ecu and i think thats all i need correct me if im wrong
Old 03-18-2003, 04:31 PM
GTA's Avatar
GTA GTA is offline
Whee..
you need the si dizzy.
AF Bay Area Crew
RIP Melt
2008 Mitsubishi Lancer Evolution GSR
2007 Toyota Prius
I <3 and miss my 4g
Old 03-18-2003, 05:15 PM
the harness should be no problem to just switch out?
Old 03-18-2003, 05:59 PM
GTA's Avatar
GTA GTA is offline
Whee..
you actually modify your dx harness to be mpfi. the si harness doesnt just plug right in.
AF Bay Area Crew
RIP Melt
2007 Toyota Prius
I <3 and miss my 4g
Old 03-20-2003, 05:25 PM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
i used a CRX Si harness in my dual point car. two interconnect plugs plug in outta the whole thing. what i did was cut off the body harness from the Si, and took the engine harness too. then using that, and the harness in my car, i made a subharness. basically all i did was match up all the matching colors, and then looked on a buncha different wiring diagrams until i came up with an adequate subharness that connects all the mismatching plugs from the SI harness and the dual point harness. still hadda run a hasport subharness for my b16 though.....but all in all i think that it came out a lot cleaner making a subharness, even though now i do have to unplug 6 interconnect plugs to take my engine out.
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
