Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 11-12-2008, 05:33 PM
90sabre 90sabre is offline
Seat belts
Ok, so this isn't my week, this is more of a question than a problem so far and I am in do it yourself mode, trying to learn. My question is, when should the seatbelts lock up or "catch". For a while I have had my son's car seat in the pass. side, and the seatbelt always seemed to "lock up" preventing the car seat from moving at all. I noticed today that no matter what I do the seat belt isn't locking up or catching, is this normal? I checked the reels and didn't notice anything strange. Thanks...
Leo
99 Ram 1500 318 4X4
Old 11-13-2008, 06:03 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: Seat belts
Snatch the belt hard like you're getting thrown into the windshield and see if it'll catch.
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
Old 11-16-2008, 12:03 AM
rockwood84 rockwood84 is offline
Re: Seat belts
most seat belts won't lock-up until during a crash. then all the seatbelts lock-up and won't a one move out. some will lock-up if you snatch on them real fast and hard.
Old 11-16-2008, 07:07 PM
Re: Seat belts
Yeah, neither of them are locking up no matter what I try, short of crashing my beloved vehicle. So this seems normal? The thing is, with the car seat, it doesn't seem to hold as tight as it did before. Anyone else have a car seat setup, in a Ram...looking for the safest setup possible(pass. airbag already off), for the occasions where I do need to use it. Thanks!
Old 11-18-2008, 07:36 PM
Re: Seat belts
While I was at the junkyard I tried a few of the seatbelts on the other Rams there with the same result, no locking, so it looks like this is normal as you mentioned earlier.
Old 11-22-2008, 09:20 PM
dugan50's Avatar
dugan50 dugan50 is offline
Authorized Vendor
Re: Seat belts
Most seat belts use an inertia trigger. That is to say there are multiple types of seat belt locking mechanisms. Here is a quote form Chrysler (it's a good example):
The seat belt retractors used in all seating positions include an inertia-type, emergency locking mechanism. The automatic locking mechanism is integral to the seat belt and retractor unit and is concealed beneath a molded plastic cover located on one side of the retractor spool. The automatic locking mechanism cannot be adjusted or repaired and, if ineffective or damaged, the entire passenger side front seat belt and retractor unit must be replaced.
You cannot make the seat belt lock unless there is motion or the retractor is removed and rotated out of the perfectly vertical position it is mounted in. Pulling rapidly on the belt will not accomplish this action.
Here is another website link that may help you.
http://www.airbagsolutions.com/docs/Pretensioners.pdf
I hope this was helpful to you. My information comes from years of experience in these businesses.
http://www.airbagsolutions.com http://www.stolenandrecovered.com
Airbag Service, Airbag Replacement, Airbag Diagnostics
Thank You,
Douglas Gan
Old 11-24-2008, 08:32 AM
AF - Advisor
Re: Seat belts
Thanks for the expert info Douglas.
What do you think of stomping the brake while moving slow then check the seatbelt slack?
Old 11-24-2008, 07:45 PM
Re: Seat belts
Excellent info! Thanks for the reply!
Leo
