Heater Issue 00" Grand Prix
I have a 2000 Grand Prix SE. Recently I noticed that my heat only gets hot when I’m accelerating or going near or over 30 mph. When I decelerate the heat cools. Not exactly sure what causes this. Also my check engine light just came on for O2 Sensor, but I don’t believe that would have any affects on the heat issue.
Re: Heater Issue 00" Grand Prix
I just went thru a similiar issue: See http://www.automotiveforums.com/vbul...d.php?t=927465
Long story short, I would flush and back flush your heater core. I would guess that the higher engine RPMs are turning the water pump faster and then the coolant circulates well enough to allow more heat. I went through a lot of trials and tribulations. But flushing that heater core is probably your best bet. Good luck |
in your SE do you have the 3800, or the 3100? first things first...check your coolant level and for any air in the system...if not, sounds like a possible headgasket.
The 2000 and up SE model should have the 3100 V6.
Do you still have the original lower intake manifold (LIM) gaskets?
